note: I have never actually used an AC motor, so feel free to correct and verify this information
Unlike DC motors which work using a single constant current,
AC motors run under 3 phase current. To have 3 phase power on a robot, you either need a big
bulky/expensive DC->AC converter, or you must tether it to a wall socket. You probably won't use AC motors
unless your robot is stationary, such as a robot arm or robot pancake maker. Unless you want the
pancake maker to also walk your dog or something . . . But here they are anyway:
Voltage
Polarized (current cannot be reversed)
Typically from 120-240V AC, usually to match mains power
Higher voltages generally mean more torque, but also require more power
Rarely used on mobile robots due to power requirements
note: A universal motor has brushes like a DC motor, but will operate on AC or DC
Current
When buying a motor, consider stall and operating current (max and minimum)
Stall Current - The current a motor requires when powered but held so that it does not rotate
Operating Current - The current draw when a motor experiences zero resistance torque
It is best to determine current curves relating voltage, current, and required torque for optimization
When a motor experiences a change in torque (such as motor reversal) expect short lived current spikes
Current spikes can be up to 2x the stall current, and can fry control circuitry if unprotected
Use diodes to prevent reverse current to your circuitry
Check power ratings of your circuitry and use heat sinks if needed
Power (Root-Mean Squared Voltage x Current)
Running motors close to stall current often, or reversing current often under high torque, can cause motors to melt
Heat sink motors if not avoidable
Torque
When buying a motor, consider stall and operating torque (max and minimum)
Stall Torque - The torque a motor requires when powered but held so that it does not rotate
Operating Torque - The torque a motor can apply when experiencing zero resistance torque
Velocity
Motors run most efficient at the highest possible speeds
Gearing a motor allows the motor to run fast, yet have a slower output speed with much higher torque
Remember that torque determines acceleration, so a fast robot with poor acceleration is really a slow robot
If uncertain, favor torque over velocity
Efficiency
More efficient than DC motors
Typically most efficient at rated voltage and frequency
Use gearing (opt to buy motors with built-in gearing or gear heads)
Control Methods
Modifying the AC frequency can alter speed and torque
Encoder - device which counts rotations of wheel or motorshaft to determine velocity for a control feedback loop
Tachometer - device which measures current draw of motor to control output torque
This circuit will allow you to control the speed of an AC motor.
The bridge rectifier produces DC voltage from the 120VAC line.
A portion on this current passes through the 10K ohm pot.
The circuit comprised of the 10k pot rated at 3W+, the two 100 ohm resistors and the 50uf capacitors delivers gate drive of the SCR.
The diode D1 protects the circuit from reverse voltage spikes.
The ratings of the bridge rectifier and the SCR should be 25 amps and PIV 600 volts.
The diode D1 should be rated for 2 amps with PIV of 600 volts.
The circuit can handle a load up to 10 amps. The SCR should be very well heat sinked.
link back, and help others in the forums! Society of Robots copyright 2005-2010
