note: I have never actually used a brushless motor, so feel free to correct and verify this information
What is a brushless motor? How is it different from a brushed motor?
Brushless motors are more power efficient, and significantly reduced electrical noise,
and last much longer. But they also have several disadvantages, such as higher prices
and the requirement for a special brushless motor driver.
Voltage
Like all motors, the torque of a motor is highly dependent on the input voltage -
higher the voltage, higher the torque. Like all other motors, brushless motors also
run on an optimal voltage - check the datasheet. If you apply too high a voltage,
the coils could melt for all the heat, and if you apply too little voltage, torque
could be quite low.
Current
When buying a motor, consider stall and operating current (max and minimum)
Stall Current - The current a motor requires when powered but held so that it does not rotate
Operating Current - The current draw when a motor experiences zero resistance torque
It is best to determine current curves relating voltage, current, and required torque for optimization
When a motor experiences a change in torque (such as motor reversal) expect short lived current spikes
Current spikes can be up to 2x the stall current, and can fry control circuitry if unprotected
Use diodes to prevent reverse current to your circuitry
Check power ratings of your circuitry and use heat sinks if needed
Power (Voltage x Current)
Running motors close to stall current often, or reversing current often under high torque, can cause motors to melt
Heat sink motors if not avoidable
Torque
When buying a motor, consider stall and operating torque (max and minimum)
Stall Torque - The torque a motor requires when powered but held so that it does not rotate
Operating Torque - The torque a motor can apply when experiencing zero resistance torque
Changing voltage will change torque
Velocity
Motors run most efficient at the highest possible speeds
Gearing a motor allows the motor to run fast, yet have a slower output speed with much higher torque
Remember that torque determines acceleration, so a fast robot with poor acceleration is really a slow robot
If uncertain, favor torque over velocity
Efficiency
Most efficient at rated voltage
Use gearing (opt to buy motors with built-in gearing or gear heads)
Control Methods
Brushless motors MUST USE A SPECIAL CONTROLLER as it works through induction
There are many different types of brushless DC motors. These motors can have from 2 to 4 poles for operation
Encoder - device which counts rotations of wheel or motorshaft to determine velocity for a control feedback loop
Tachometer - device which measures current draw of motor to control output torque
link back, and help others in the forums! Society of Robots copyright 2005-2010
