note: I have never actually used a linear motor, so feel free to correct and verify this information
Special notes on linear motors
Linear motors are like flat X-Y induction motors
The ends of the motor plane have hard to predict magnetic fields and must be accounted for
There are many types of linear motors: Voice coil motor, Brushless AC servo motor, Stepping, and variations of these
Brushless iron-core linear motors must have low cogging force (2% or less)
3 phase motors must have low a force ripple
Ratio of thrust to moving mass determines the load capacity of a linear motor.
Less moving mass means more capacity for external load. In addition, the reaction force
due to moving mass under high acceleration and deceleration will result in considerable
vibration to your machine and may lead to unpredictable resonance. So, a good linear motor
stage must keep its moving mass as small as possible.
Consider if you want to move both axis simultaneous and/or independent
Duty cycle must be kept low to avoid overheating
A good linear motor stage must make its number of moving cables as few as possible to increase longevity
Other factors to consider: Effective stroke, Resolution, External Payload, Moving Mass, Accuracy,
Repeatability, Straightness/Flatness, Maximal Velocity, Maximal Acceleration, Coil Inductance
Voltage
Dependent on type of linear motor
Higher voltages generally mean more torque, but also require more power
Motors can run above or below rated voltage (to meet other design requirements)
Most efficient at rated voltage
Current
When buying a motor, consider stall and operating current (max and minimum)
Stall Current - The current a motor requires when powered but held so that it does not move
Operating Current - The current draw when a motor experiences zero resistance torque
It is best to determine current curves relating voltage, current, and required torque for optimization
When a motor experiences a change in torque (such as motor reversal) expect short lived current spikes
Current spikes can be up to 2x the stall current, and can fry control circuitry if unprotected
Use diodes to prevent reverse current to your circuitry
Check power ratings of your circuitry and use heat sinks if needed
Power (Voltage x Current)
Running motors close to stall current often, or reversing current often under high torque, can cause motors to melt
Heat sink motors if not avoidable
Torque
When buying a motor, consider stall and operating torque (max and minimum)
Stall Torque - The torque a motor requires when powered but held so that it does not rotate
Operating Torque - The torque a motor can apply when experiencing zero resistance torque
Changing voltage will change torque
Velocity
Motors run most efficient at the highest possible speeds
Gearing a motor allows the motor to run fast, yet have a slower output speed with much higher torque
Remember that torque determines acceleration, so a fast robot with poor acceleration is really a slow robot
If uncertain, favor torque over velocity
Efficiency
Friction is a concern at slower speeds
Use gearing (opt to buy motors with built-in gearing or gear heads)
Control Methods
Dependent on motor type
Most linear motors come with special controllers
link back, and help others in the forums! Society of Robots copyright 2005-2010
