Search and Index Search Here
    ELECTRONICS & SCHEMATICS FOR ROBOTS
    Advanced Electronic Components Advanced Electronic Components
    Transistors, MOSFETs, relays, voltage regulators, potentiometers, etc.
    Basic Electronic Components Basic Electronic Components
    Resistors, capacitors, diodes, etc.
    Battery Monitor Circuit Battery Monitor Circuit
    Let your robot know when it is hungry.
    Bluetooth Wireless for Robots Bluetooth Wireless for Robots
    Impliment a wireless connection between your robot and your computer using Bluetooth.
    Crystal for Microcontrollers Crystals for Microcontrollers
    Learn how to select and add crystal oscillators to your microcontroller to soup up the speed.
    Current Sensor Current Sensor
    Measure current and power use accurately with a current sensor.
    DC Motor Braking DC Motor Braking
    Learn 3 methods on how to break (stop from rotating) your DC motor.
    Eagle3D Tutorial Eagle3D Tutorial
    Convert your 2D Eagle CAD files into impressive 3D graphics! Find errors in your PCB design before you manufacture it.
    Eagle Export Tutorial Eagle Export Tutorial
    After you designed your PCB in Eagle, learn how to export the gerber files properly to send to your PCB manufacturer.
    Fuse Tutorial for Robots Fuse Tutorial for Robots
    Learn how to rate and use fuses, and how to choose wire gauge. Protect your expensive robot components!
    How to Create Negative Voltages (Using MAX232 IC) How to Create Negative Voltages (Using MAX232 IC)
    Create negative voltages using the MAX232 IC negative charge pump.
    How H-Bridges Work How H-Bridges Work
    H-Bridges allow digital control of high powered equipment. Find out how H-Bridges work.
    Infrared Emitter/Detector Pair Infrared Emitter/Detector Pair
    Detect and emit light in the infrared spectrum for obstacle avoidance.
    IrDA IR Trasciever, Bluetooth, Axon IrDA IR Transceiver Tutorial and Bluetooth Demo
    I custom made a long range IrDA compatible IR transceiver complete with encoding/decoding. I'm demonstrating it using the Axon microcontroller, and using Bluetooth to upload data to my PC.
    Lead Testing Tutorial and RoHS Lead Testing Tutorial and RoHS
    Ever got your PCB boards assembled or manufactured and want to know if they are RoHS compliant? This tutorial shows you how.
    LED Tutorial LED Tutorial
    Learn how to select your LED and resistor based on your operating parameters.
    Power Regulation Power Regulation
    Learn how to regulate a changing voltage to a constant one.
    Remote Control Robots Tutorial Remote Control Robots Tutorial
    Make your robot remote controlled (RC). Learn the difference between automaton, remote control, teleoperational, and fully autonomous. Learn about the various components needed to make a robot remote control.
    Voltage Amplifiers Voltage Amplifiers
    Build a voltage amplifier using an op-amp.
    Wire Connector Tutorial Wire Connector Tutorial
    Learn the 'professional' way to connect your wires between circuit boards and external components.
