ROBOT DYNAMICS
Introduction to Mechanical Engineering Theory, Dynamics
While statics is the study of structures
at a fixed point in time, dynamics is the study of structures over a period of time.
Basically statics studies things that dont move, while dynamics studies things that do.
Statics is concerned with moments, forces, stresses, torque, pressure, etc. Dynamics is concerned
with displacement, velocity, acceleration, momentum, etc. If you want to calculate
and/or optimize forces generated or required for a moving robot, this tutorial has the basics
that you will need to understand. It is highly recommended you read the statics tutorial first
as this tutorial will build off of it.
Displacement and Velocity
We all know what velocity is, but how do you design a robot to go at a defined velocity?
Of course you can put a really fast motor
on your robot and hope that it will go fast enough.
But if you can calculate it you can design it to go your required speed without doubt, and leave the rest
of the motor force for torque.
So how to do this? For an example, suppose you have a wheeled robot that you want to run over
old people with. You know from experiments that old people can run at 3 feet per second. So what
motor rpm do you need, and what diameter should your wheels be, so they cant get away or hide their
medicine?
Conceptually, every time your wheel rotates an entire revolution, your robot travels the distance equal
to the circumference of the wheel. So multiply the circumference by the number of rotations per minute,
and you then get the distance your robot travels in a minute.
Velocity = circumference * rpm
Velocity = diameter * pi * rpm OR Velocity = 2 * radius * pi * rpm
For example, if your motor has a rotation speed (under load) of 100rpm (determined by looking up the motor part
number online) and you want to travel at
3 feet per second, calculate:
3 ft/s = diameter * pi * 100rpm
3 ft/s = diameter * pi * 1.67rps (rotations per second)
diameter = 3 ft/s / (3.14 * 1.67 rps)
diameter = 0.57 ft, or 6.89"
Robot Wheel Diameter vs Torque
You probably noticed that the larger the diameter of the wheel, or higher the rpm, the faster your robot will go.
But this isn't entirely true in that there is another factor involved.
If your robot requires more torque than it can give, it will go slower
than you calculated. Heavier robots will go slower. Now what you need to do is compare the motor torque,
your robot acceleration, and wheel diameter. These three attributes will have to be
balanced to achieve proper torque.
Motor Torque and Force
High force is required to push other robots around, or to go up hills and rough terrain, or have high
acceleration. As calculatable with statics, just by knowing your
wheel diameter and motor torque, you can determine the force your robot is capable of.
Torque = Distance * Force
Distance = Wheel Radius
Force = Torque / Wheel Radius
Acceleration
But you also want to be concerned with acceleration. For a typical robot on flat terrain, you probably want acceleration
to be about half of your max velocity. So if your robot velocity is 3 ft/s, you want your acceleration
to be around 1.5 ft/s^2. This means it would take 2 seconds (3 / 1.5 = 2) to reach maximum speed.
Remember that:
Force = Mass * Acceleration
There is one other factor to consider when choosing acceleration. If your robot is going up inclines
or through rough terrain, you will need a higher acceleration due to countering gravity. If say
your robot was going straight up a wall, you would require an additional 9.81 m/s^2
(32 ft/s^2) acceleration to counteract. A typical 20 degree incline (as shown) would require 11 ft/s^2.
How do you calculate how much additional acceleration you would need for a specific incline?
acceleration for inclines = 32 ft/s^2 * sin((angle_of_incline * pi) / 180)
You must add this acceleration to what you already require for movement on flat terrain.
Note that motor acceleration and torque are not constants, and that motor acceleration
will decrease as motor rotational velocity increases. As it's very dependent on the motor,
this tutorial will gloss right over it for simplicity.
Robot Motor Factor
The robot motor factor (RMF) is something I made up. It is simply a way I devised to make your life simpler
so you can do a quick calculation to optimize your robot. Basically I combined and simplified
all the equations above into one big equation to help you choose the motor that best suits your
robot.
Torque * rps > = Mass * Acceleration * Velocity / (2 * pi)
RMF = Torque * rps
1) To use this equation, look up a set of motors you think will work for your robot and write down
the torque and rps (rotations per second) for each.
2) Then multiply the two numbers together for each. This will be your robot
motor factor.
3) Next, estimate the weight of your robot. Basically add up the weight of all the parts.
4) Lastly, choose your desired velocity and acceleration.
5) Compare both sides of the equation
Example. Suppose you found three motors:
Motor A: 2 lb ft, 1rps => RMF = 2 lb ft rps
Motor B: 2.5 lb ft, 2rps => RMF = 5 lb ft rps
Motor C: 2 lb ft, 4rps => RMF = 8 lb ft rps
Now suppose you want a velocity of 3 ft/s, an acceleration of 2 ft/s^2, and you estimate
your robot weight to be 5 lbs.
so RMF >= 5 lbs * 2 ft/s^2 * 3 ft/s / (2 * pi)
therefore RMF >= 4.77 lb * ft * rps
So this means you need a motor with an RMF greater or equal to 4.77. Looking at your list,
Motor B and C both will work. However Motor C is probably overkill, so it's just a waste of
money. Therefore you would use Motor B. Just note that if none of the motors would work,
you would have to either reduce weight, or go slower, or find another motor.
note: if you convert rps to radians/sec, RMF can be measured in watts
Calculating Wheel Diameter
So now what robot wheel diameter should you use?
Going back to an earlier equation,
velocity = diameter * pi * rps
OR
diameter = velocity / (pi * rps)
3 ft/s / (pi * 2/s) = wheel diameter = .48 feet = 5.73"
You are finished! You use motor B, with a wheel diameter of 5.73", and never again will
your robot fail at plowing over the neighborhood cat.
Although the above equations are intended for robot wheels, they will also work for any other
robot part. If you were say designing a robot arm, instead of using diameter use robot
arm length. Then you can calculate how fast the arm will move with a certain weight being
carried, for example.
Robot Motor Factor, Efficiency
The RMF you calculated is only for a 100% efficient system. But in reality this never happens.
Gearing and
friction and many other factors cause inefficiency.
I won't go into how to calculate efficiency, but there are general rules that would get you really close.
If you have external (not inside the motor) gearing, reduce your efficiency by ~15%. If you
are using treads like on a tank robot, reduce by another ~30%. If your robot operates on
rough high friction terrain, reduce another ~10%. For example, a tank robot on rough terrain
would have an efficiency of (100% - 30%)*(100% - 10%) = 63% or 0.63.
The RMF equation, incorporating efficiency, is
Torque * rps > = Mass * Acceleration * Velocity * (1/efficiency) / (2 * pi)
where efficiency is a percentage expressed as a decimal number (i.e. 80% = .8).
Momentum
Ever notice how heavier things are harder to push than lighter things? This is because of
momentum. Knowing your robot's momentum is very important if you want high acceleration
for your robot. If your robot is heavy, it will take forever for a weak motor to get it
to go fast. How do you determine the momentum of your robot? Just multiply the mass
times the velocity. Lower momentum is better for mobility and higher
energy efficiency. Higher momentum is better for beating up other robots . . . and people.
Momentum = Mass * Velocity
