What is a Differential Drive Robot?
The term 'differential' means that robot turning speed is determined by the speed difference between both wheels, each on either side of your robot. For example: keep the left wheel still, and rotate the right wheel forward, and the robot will turn left. If you are clever with it, or use PID control, you can get interesting curved paths just by varying the speeds of both wheels over time. Dont want to turn? As long as both wheels go at the same speed, the robot does not turn - only going forward or reverse.
The differential drive algorithm is useful for light chasing robots. This locomotion is the most basic of all types, and is highly recommended for beginners. Mechanical construction, as well as the control algorithm, cannot get any simpler than this. Note that this algorithm doesnt just work for wheeled robots, but is also the same algorithm you must use for tank tread type robots and biped robots. For examples of differential drive robots, see my sumo robot, mobipulator robot, and robot boat.
How to Use This Algorithm
pseudocode:
make decision based on sensor reading do one of below actions: to drive straight both wheels move forward at same speed to drive reverse both wheels move back at same speed to turn left the left wheel moves in reverse and the right wheel moves forward to turn right the right wheel moves in reverse and the left wheel moves forward Two robot soccer teams of custom differential drive robots:
