    SUMO ROBOT CONSTRUCTION - STAMPY
    Sumo Robots
    This robot has been designed for the DC Sumo Competition for January of 2007. Unlike your typical sumo robot competition, the rules limit brute speed and strength. By imposing speed limits on all robots, it eliminates the 'smash and bash' in exchange for increased robotic intelligence and sensors use.
    In the spirit of sumo, I named my robot Stampy.
    Stampy the elephant, on Simpsons
    Strategy
    Never go into battle without a clever strategy. Stampy employs a clever strategy of using the opponents force against itself. Instead of pushing back by a frontal collision, it tries to wedge its ramp under just a single wheel of its opponent.
    My sumo robot is better than yours!
    As the opponent robot continues to drive, it will start to tilt over. As this happens, Stampy changes direction and continues to push the opponent the rest of the way over. Its not about pushing the opposing robot out of the ring, but instead flipping it over. Just watch the video before continuing:
    Algorithm
    The algorithm takes data from a scanning Sharp IR Rangefinder, and uses edge detection to decide where to drive. If no target is available, it would go into a search mode and spin clockwise. Otherwise, it would attempt to drive towards the left side of the opposing robot.
    This is the cheapest and simplest method for a robot to locate and follow other objects.
    pseudocode:
      //scanner code
      if sharp IR detects object
          scanning IR turns left
      else //no object detected
          scanning IR turns right
      //robot motion code
      if scanner is pointing far left
          robot turns left
      else if scanner is pointing far right
          robot turns right
      else //scanner pointing forward
          robot drives straight
    As shown, the scanner goes left if it sees a googly-eyed robot. If it doesnt detect it, the scanner turns right until it does. As a result, the scanner converges on the left edge of the googly-eyed robot:
    Sharp IR Scan Edge Detection
    The algorithm is guaranteed to converge on a stable point if the scanner locates the object from the left edge. But if the object is detected on the right edge, there is no convergence. This can potentially cause a problem:
    No Convergence Edge Detection
    The solution: if the sensor misses the object and rotates to the right to its maximum position, tell the scanner to reset its angle to the far left. There is also the solution of using two scanners so that there is a convergence on both the left and right edges of the object. But for the purposes of sumo I couldnt do this.
    My commented sumo robot source code is available for download.
    Stealth Technology
    As your opponent robots get smarter, and start using sensors to detect your robot, countermeasures need to be applied. Stampy employs three such stealth technologies.
    IR/LED Defence
    Two popular methods of robot sensors are infrared emitter/detectors and photoresistors with reflective LED's. To counter these sensors, you need to coat your robot in an IR/visible light absorbant paint. Make sure the paint has a rough coat, as a shiny coat is more reflective. I used black acrylic paint, but I didnt test it to see how well it works. Another popular sensor used is the Sharp IR Rangefinder. This sensor is significantly more immune to surface color, but it will still have some decreased accuracy.
    Sonar
    Sonar is the other popular method of sensing for sumo robots. Sonar has two weaknesses - the 'softness' of the target, and the angle of the target. Coat your robot in sound absorbing pointy shaped foam.
    Sound Absorbing Foam
    The other method is similar to stealth aircraft - use flat surfaces and sharp angles to deflect the sonar. I extended the ramp across the entire robot frontal area for sonar reflection, and use black foam wheels for light and sound absorption (plus, foam is good for traction). These methods will significantly decrease the detectable range of your robot.
    Robot Stealth
    Active Sensor Avoidance
    Sensor avoidance is where your robot either sees or predicts where the enemy robot sensors are directed, and then moves away from it. Stampy avoids at all times from being in front of the target robot, and instead side swipes. A defence sensor avoidance would be to use a scanning sensor instead of a fixed one, such as what Stampy employs.
    Standing Up to Save Space
    All sumo competitions have restrictive length and width limits, but rarely any restrictive height limits. To make Stampy eligible for these other competitions (and just for demonstration), it was designed to start off vertical, and flip itself down for attack mode. By starting off in vertical mode, the length restriction is bypassed.
    Stampy in Vertical PositionStampy in Horizontal Position
    For a ramp based sumo robot, you want all the weight up at the front (to push the ramp down). So when in vertical position, all the weight is high up. To go to horizontal position, Stampy simply drives backwards for half a second.
    Assembly
    My very first step to building Stampy was to design it in CAD:
    Sumo Robot CAD
    Feel free to explore the 3D CAD by clicking with your mouse:
    You can download the CAD files for AutoDesk (2.2mb), or if you do not have AutoDesk, you can download the design drawings. You may also download the Stampy DWF.
    Robot Design Sketch
    My next step was to prepare my parts for CNC machining. Most of the parts are fairly simple and do not require CNC, but I wanted more practice at CNC and for it to look professional. I used EdgeCAM for CNC simulation and G-Code generation:
    CNC Simulation CNC Simulation
    I have included the G-Code for both of those parts. It was written for the Haas Mill, but with minor modifications it would work on any CNC machine. Note that the part called Frame had additional holes drilled into it, and two fillets (located by the servo) removed with a mill bit, with a desktop drill press.
    Materials used was what I had around, sheets of HDPE, aluminum, and copper.
    assembly images:
    all of the parts disassembled
    Robot Sumo Parts
    attached sides, bottom, and servos
    Robot Sumo Assembly Step 1
    attached battery by velcro, and attached the lower ramp
    Robot Sumo Assembly Step 2
    screwed in wheels, and added spacers for electronics mount
    Robot Sumo Assembly Step 3
    assembled scanner
    Robot Sumo Assembly Step 4
    added upper ramp, attached electronics, attached velcro for scanner
    Robot Sumo Assembly Step 5
    attached scanner, remachined the side Frame (there were errors), and painted ramp black with acrylic paint
    Robot Sumo Final Assembly
    Time Log
    Total time required to create this robot was ~25 hours. The meticuously recorded breakdown of hours:
    time to CAD: 2 hours 40 minutes
    programming: 4 hours 20 minutes
    part machining: 4 hours
    creating CNC g-code: 45 minutes
    CNC: 2 hours 30 minutes
    assembly: 1 hour 30 minutes
    fixing mistakes: 4 hours (remachining and assembling Frame)
    test programming: 3 hours 40 minutes
    video filming: 1 hour
    Additional notes on time:
    Since I reused a lot of my CAD files, code, and parts from older robots, my time log is a bit skewed. It probably saved me an additional 10+ hours of work.
    Cost/List of Parts
    As I already owned all parts that were used on this robot, I spent $0 to produce the entire thing.
    But if I were to go out and purchase parts, this would be the rundown:
      Cerebellum Microcontroller: $60 (no longer sold)
      HS-311 Servo: $10
      Sharp IR: $15
      HDPE, Aluminum, Copper Sheeting: $20
      1800mAh 6V NiMH Battery: $13
      2 Foam Wheels: $8
      Spacers, screws, velcro: $10
      Two HS-225MG Servos: $28 each
      Acrylic paint: $5
      Total: ~$197
    Bonus Video!
    Just for fun I decided to have a battle between the $50 Dollar Robot (remote control mode, driven by me) and Stampy. This shows autonomous robots kick bot! (ok sorry, really bad pun . . .)
