Society of Robots
     | Robot Forum | Robot Tutorials | Robot FAQ |
Welcome, Guest. Please login or register.
Did you miss your activation email?
November 20, 2009, 08:34:31 PM
Login with username, password and session length
Search:     Advanced search
Sept 30th - New Price - Axon is now $94
Robot Forum
72,665 Posts in 9,267 Topics by 5,290 Members
Latest Member: robertelson
* Home Help Help Login Register
Pages: [1] 2 3 4 Print
Author Topic: CAD of my newest robot  (Read 21630 times)
AdminTopic starter
Administrator
Supreme Robot
Helpful? 62
Offline Offline
View Profile WWW
« on: June 02, 2007, 05:19:43 PM »
Ive probably made 30+ robots in the last 5 years, and decided I waste a lot of time building a new chassis each time . . .
So now Im working on a one-size-fits-all robot test platform. Im designing it to be easy for anyone to make. It also has a special upgrade platform to add whatever I want without rebuilding the whole robot. It will use the same controller as from the $50 Robot.
I want opinions on it - so if anyone wants to use the design it will be useful.
This is the 'bare-bones' platform, a simple diff drive with a castor:
This is the experiment platform that can be changed out depending on 'mission' requirements:
This is an example of what can be added to the experimental platform:
I will use this bot for the next 5+ or so tutorials, including pathfinding, mapping, more vision and sonar stuff, wireless communications, and more! (the red line is a laser pointer that will be controlled by the robot)
Here is a video simulation I did for the prototype:
Logged
ed1380
Supreme Robot
Helpful? 2
Offline Offline
View Profile
« Reply #1 on: June 02, 2007, 08:03:38 PM »
looks awesome. only concern is how would the caster work when turning? or is it one of those wheels that have rollers on them?
« Last Edit: June 05, 2007, 12:46:19 PM by Admin » Logged
AdminTopic starter
Administrator
Supreme Robot
Helpful? 62
Offline Offline
View Profile WWW
« Reply #2 on: June 05, 2007, 12:46:27 PM »
apologies for my lazy CAD'ing . . . omni wheels are hard to make! Tongue
its the same omni wheel as:
Logged
AdminTopic starter
Administrator
Supreme Robot
Helpful? 62
Offline Offline
View Profile WWW
« Reply #3 on: June 05, 2007, 06:52:32 PM »
I decided that all my robot could do is just wander around (boring) . . . so I decided to add a basic 3 DOF robot arm to it so it can poke stuff. I have some ideas of doing realtime visual servoing without doing trig or frame transposing (hard/intensive stuff) that Ive been wanting to try, anyway.
In the future I could always actuate the claw, but for now Ill keep it simple.
I also added a sinewinder in front to pimp it up a bit Grin
Logged
AdminTopic starter
Administrator
Supreme Robot
Helpful? 62
Offline Offline
View Profile WWW
« Reply #4 on: June 09, 2007, 01:38:21 PM »
I just ran some stress analysis simulations on the robot arm . . . it turns out my original design was way overkill. Ideally you want the robot arm as small as possible to keep weight as low as possible . . . but if you make it too thin then it starts bending too much. Im a mechanical engineer, I dont just use intuition when it comes to mechanics Wink
I ran the analysis applying 4 to 5 pounds at various locations (the robot itself only weighs 2 pounds). Below is just some of what I did. Click for enlarged images. Btw, my older design was able to handle over 100 pounds, but was too heavy Tongue
A deflection test of 4 pounds, with maximum deflection of .23"
The new optimized arm:
Logged
Brandon121233
Contest Winner
Supreme Robot
Helpful? 0
Offline Offline
"Genius is %1 inspiration and %99 perspiration"
View Profile
« Reply #5 on: June 09, 2007, 05:15:42 PM »
I'm not sure if you mentioned this somewhere already yet but what program did you make and test this in? It looks neat being able to run stress tests.
Logged
        —Thomas Edison
AdminTopic starter
Administrator
Supreme Robot
Helpful? 62
Offline Offline
View Profile WWW
« Reply #6 on: June 09, 2007, 06:00:02 PM »
Im currently trying out Autodesk Inventor 2008 . . . it apparently has ANSYS built in for FEA.
In more updates, I just calculated that with the servos Im using (HS-225 MG), the arm can lift 2.6 pounds plus its own arm weight before stalling. The robot now weighs ~2.7 pounds, so it can almost bench its own weight! Tongue
Im now checking the CAD for dumb mistakes and I will hopefully start CNC'ing the parts next week.
I still havent made a decision on which camera I will use yet . . . Ill do that later I guess . . .
Logged
AdminTopic starter
Administrator
Supreme Robot
Helpful? 62
Offline Offline
View Profile WWW
« Reply #7 on: June 09, 2007, 08:11:43 PM »
Since this robot has a robot arm, I had to do some various calculations to get it perfect. Tongue
As always with my projects, all tools I develop become free for anyone. This time, I developed a program that can do all the math for you if you ever wanted to build a robot arm. It even shows you what the arm will look like given your parameters.
Check out my Robot Arm Designer v1 (in excel).
To use it, all you do is enter your design parameters in the yellow boxes, and the calculated values appear in red. It also does both forward and inverse kinematics for you. At the moment it is only for a 3 DOF arm:
Ill probably get 6 or so tutorials out of this project Grin
Logged
maverick monk
Robot Overlord
Helpful? 0
Offline Offline
View Profile
« Reply #8 on: June 10, 2007, 04:30:24 AM »
oh, so fancy, lol. now you need to figure out a way to use that arm to get into the fridge and bring you your favorite drink, if you do that, i want a tutorial for that too.
Logged
AdminTopic starter
Administrator
Supreme Robot
Helpful? 62
Offline Offline
View Profile WWW
« Reply #9 on: June 16, 2007, 09:33:11 AM »
Ok so I started constructing this critter of a robot . . .
Made all the parts, then realized I sized all my holes too big . . . so I had to make all the parts again . . .
So here are a few pics of the current level of assembly. I still have yet to decide on which camera to use, so I left that part out for now.
There are unfortunately two more mistakes I made . . .
I forgot that I already modified the servos I am using for the arm, so now I need to buy two new ones (doh!).
Also, I realized my Robot Arm Designer has a flaw in it I cant figure out. For some reason the inverse kinematics do not work outside of quadrant I (doesnt work for negative positions). Can anyone good in math figure out what Im doing wrong? Undecided
Logged
Tsukubadaisei
Robot Overlord
Helpful? 0
Offline Offline
View Profile
« Reply #10 on: June 16, 2007, 08:52:42 PM »
In that case sir, allow me to to explain you problem:
When you calculate theta and psi(by the way the symbol for psi in your tutorial is wrong as well. It is not Φ but Ψ, the one that you used is the symbol for phi), you are forgetting that the equation has 2 solutions and you are considering only the positive one for both angles. In that case you will only get the solution in the first quadrant. Embarrassed
In other words:
let K=(x^2 + y^2 - L1^2 - L2^2) / (2 * L1 * L2) and C=(y * (L1 + L2 * c2) - x * L2 * s2) / (x^2 + y^2)
then in ADMIN's answer we get
psi=arccos(K) and theta=arcsin(C)
but, unfortunatelly, that is just one case.
Why? Simple, if you try to solve that equation step by step you will first and up in this equation:
K=cos(psi)
Now lets examine psi. Psi can be both positive and negative, and one of the properties of cosine is the following:
cos(x)=cos(-x)=cos(abs(x)), where abs(x) is the absolute value of x. Considering the range of Psi you nescessarely have to you consider abs(x), because both negative and positive values give the same result. It is exactly when you are solving x^2=1, if you are solving this equation in the most formal way you will get:
x^2=1 <=> abs(x)=1 <=> x=+/-1 where +/- is the plus-minus signal
Returning to the topic you will then get the following result:
K=cos(psi) <=>abs(psi)=arccos(K) <=> psi=+/-arccos(K)
then you use this result in order to solve theta and get:
theta=-/+sin(C)
In the and your final equation will be:
psi =+/- arccos((x^2 + y^2 - L1^2 - L2^2) / (2 * L1 * L2))
theta =-/+ arcsin((y * (L1 + L2 * c2) - x * L2 * s2) / (x^2 + y^2))
c2 = (x^2 + y^2 - L1^2 - L2^2) / (2 * L1 * L2);
s2 = sqrt(1 - c2^2);
Now you ask me: Thanks, but how am I supposed to do create a Excel file with a graph for that? Ans: As far as I know, you can't. I advise you to use MATlab, but still it would be very difficult.
Now there are 2 things that I can't understand in this robot arm.
1) Why is ADMIN trying to caltulate the inverse kinematics equation? An arm that does more than 1 rotation movement will get multiple answers because there are more than one way to move to a certain point and you will get a nightmare equation in the end that will drive you crazy when programing it. Not to mention that your controller will that forever to compute the results.( maybe for this robot it is still possible, but try a slightly more complex robot and you will never be the same anymore)
I believe that the best way to calculate this moviment is actually getting the position of the target, then the position of the arm and calculate the actual angle you have to rotate. I mean:
X=FUNCTIONTHETA where X is the vector that describes the position of the arm, FUNCTIONTHETA is the vector function of the angles. Let D mean the difference( for example DY=Y2-Y1)
than, you calculate the derivative and get
DX=DFUNCTIONTHETA=J*DTHETA where J is the Jacobian matrix and THETA the angle vector.DX is the linear displacement and DTHETA is the angular displacement for each servo. Since you have the linear displacement then you want to calculate the angular displacement. In that case you calculate the inverse of the Jacobian Matrix. You will get in the end:
DTHETA=J^(-1)*DX
It is a boring process but 100% safe. And easy to program (just use arrays and math.h in C and you are done).
2) the second thing I can't understand is the hand of the robot. That hand can't close. I know you may just want to put some beer on let the robot transport it. But in my opinion, a hand that can't close is like a plane that can't fly.
Now, enough of boring maths, I will post my robot as well. I am doing it mainly for 2 competitions that will be held in September and October and for the 200 bucks contest in the end of July, I think. I am very busy now so I haven't started building it yet, I will start in the and of June.
The ojective is to transport that apple over a outdoors irregular field full of obstacles without letting the apple fall. Except by the apple, according to the rules, I cannot have anything over the top most plataform. Yes, that is right, it is a nightmare. I think I might change the tires for something softer(I am using gum, but I will choose another type of gum and a bigger pneumatic tire). And since I bought a tiny UMPC I might add a camera in order to help the 4 sonars I am using (the fith one is for cheking the position of the apple). The movement system is very similar to ADMIN's Taurus 2. There is a part with some lines so I will be using line tracer as well. My sponsors are Freescale and Futaba, so I am getting the controller and the servos(11 of them) for free. There are a few more features and sensors in this robot but I will leave then for the tutorial later. The robot looks big but it is actually 30X30X25cm^3
 Shocked OMG, This post is too big. sorry
« Last Edit: June 16, 2007, 09:01:06 PM by Tsukubadaisei » Logged
Ro-Bot-X
Contest Winner
Supreme Robot
Helpful? 10
Offline Offline
Current project: MiniEric robot.
View Profile
« Reply #11 on: June 17, 2007, 12:34:23 AM »
Whoa! I don't understand any of that math... I guess this is what I'm missing by not having a university degree...
It makes a lot of sense to calculate the difference in the actual position of the arm and the desired position. I am building a big robot that will have 2 arms, one with 6DOF and one with less, probably 3 or 4. Since I don't know the math, I will make something like a lookup table with stored positions. But this will not be enough, so there will be adjustments based on camera image processing. Hmm, I see it is hard to explain.
About the robot, it looks great! Suggestion: get inflatable tires, and inflate them half way. You will have a soft rocking movement and the apple will have a better chance to stay in place.
Edit: Yeah, where is the claw ADMIN? When I saw your CAD I thought you minimalised it but you have in mind to install one...
« Last Edit: June 17, 2007, 12:36:35 AM by Ro-Bot-X » Logged
Check out my new blog!
 SeriousRobotics
Ro-Bot-X
Contest Winner
Supreme Robot
Helpful? 10
Offline Offline
View Profile
« Reply #12 on: June 17, 2007, 12:48:04 AM »
Admin, as I was looking at your robot, it stroke me that it has too much weight on the front and too little support for the balance of the arm movement. You will lose adherence (your wheels will slip) if driving on a smooth surface... I would have mounted the arm over the driving wheels, a little to the back, for better stability and traction.
Logged
 SeriousRobotics
AdminTopic starter
Administrator
Supreme Robot
Helpful? 62
Offline Offline
View Profile WWW
« Reply #13 on: June 20, 2007, 06:34:28 PM »
I got progress to report. Ill let the video do all the talking Grin
I have officially called it ERP for Experimental Robot Platform.
I havent had time to go back over my math yet, but I did however write up a really fast trig lookup table calculator for the AVR to use later. Im still debating if I just want to fudge the arm motions with fuzzy logic or stick with inverse kinematics. Ill play around with it a bit more first and see what it can do.
Dont worry its coming. This is an ERP so it will be forever upgraded with new human killing features. I just wanted to get a basic base and basic software to start off with.
Yea Im sort of having this problem. The arm is soooo fast and soooo strong that the whole base moves when the arm does. If you look carefully you can see it in the video. Its a dynamic issue I didnt really consider and I suck at calculating. Im going to have to analyze it to see what I can do. In the mean time Ill add a second NiMH battery to weigh it down by another ~30%.
Logged
Ro-Bot-X
Contest Winner
Supreme Robot
Helpful? 10
Offline Offline
View Profile
« Reply #14 on: June 20, 2007, 11:53:33 PM »
I think I didn't explain right what I was thinking. I meant to say that I would had the omniwheel at the back of the robot (the back of your robot would be the front) and have the arm above the driving wheels but inside the triangle made by the 3 wheels touch points on the ground. and the battery weight over the omni wheel for counter ballancing. Does this make more sense?
Logged
 SeriousRobotics
gamefreak
Supreme Robot
Helpful? 1
Offline Offline
Robo-Enthusiast
View Profile
« Reply #15 on: June 21, 2007, 04:53:56 AM »
Admin, wouldnt you actually want the hand to bend a little bit?, this would allow the robot to pick things, of course, it wouldnt be able to put them back down unless another arm started pulling,
=cos(psi)
is it normal to have a headache now?
Logged
Tsukubadaisei
Robot Overlord
Helpful? 0
Offline Offline
View Profile
« Reply #16 on: June 21, 2007, 07:39:21 PM »
Yes, do you want some aspirins? Wink
Logged
megaman935
Robot Overlord
Helpful? 0
Offline Offline
View Profile
« Reply #17 on: June 22, 2007, 07:54:48 AM »
uuugghh... ANYTHING PLZ! Cry
P.S. Admin Awesome Robot! Grin
What would happen if you took 2 more servos and make the hand move to pick up things too? just a thought..
« Last Edit: June 23, 2007, 06:23:12 PM by megaman935 » Logged
S. Karim
Robot Overlord
Helpful? 0
Offline Offline
View Profile
« Reply #18 on: July 01, 2007, 05:44:05 PM »
how big are cnc machines? is it possible to buy an affordable one, thats not huge, anytime soon?
Logged
KambeiX
Full Member
Helpful? 0
Offline Offline
View Profile
« Reply #19 on: July 01, 2007, 06:16:23 PM »
the video looks great, you should equip the arm with an axe for robot crushing battles Tongue
Logged
AdminTopic starter
Administrator
Supreme Robot
Helpful? 62
Offline Offline
View Profile WWW
« Reply #20 on: February 17, 2008, 04:42:13 PM »
Wow I can't believe its been 8 months since my last update . . . hmmmm so I guess I should post an update so you guys don't think I've fallen behind too much . . .
Attached is what it currently will look like with all my new upgrades. Lets give a quick rundown here . . .
I've added a second arm, and it has a claw to grab stuff. I don't plan to ever have both arms the same as I want to play around with different claw ideas.
I got bluetooth wireless working - transmitting data, commands, etc.
Wireless bootloading works.
I am swapping out my $50 Robot controller for my new Axon microcontroller. I will post code for both in the future for others to use.
I swapped out the servos in the base of each arm to more expensive/stronger servos. It can now easily (as calculated) do pullups with its two arms.
I increased the robot height so the camera can see better, and so that I can have two levels of space to add upgrade sensors/components.
I increased wheel diameter to increase robot speed, and the wheels are now custom made and ultra light weight/thin.
I got a new 4200mAh battery, giving a calculated 3 full hours of continuous runtime.
Oh and I just spent another $250 in parts . . .
Three things left to do . . . and I have until the mid April MOBOT contest to finish:
1) CNC and assemble the new design
2) Get the CMUcam to work
3) Integrate all my sub-programs in code to work together
Logged
paulstreats
Supreme Robot
Helpful? 12
Offline Offline
View Profile WWW
« Reply #21 on: February 17, 2008, 04:49:49 PM »
The new cad is looking a lot more like a professional robot Grin
Are you going to use your new AXON board as a sole mcu for it?
Logged
AdminTopic starter
Administrator
Supreme Robot
Helpful? 62
Offline Offline
View Profile WWW
« Reply #22 on: February 17, 2008, 05:01:48 PM »
yeap, thats what the Axon was designed for Grin
although in the future I might have a remote PC perform additional AI or something else processor intensive . . .
Logged
AdminTopic starter
Administrator
Supreme Robot
Helpful? 62
Offline Offline
View Profile WWW
« Reply #23 on: February 23, 2008, 11:16:19 AM »
Over the last ~3 days I CNC'd and assembled my ERP. He is all wired up too, minus the batteries that have yet to come in the mail.
I am working on programming him now, but I was dumb and forgot my programming cable at work . . . so I can't test my code, but I'll get most of it done this weekend hopefully.
I also broke a servo gear while trying to mod it . . . so got to order a replacement gear set before it can run around . . .
A few pics attached.
Logged
garriwilson
Supreme Robot
Helpful? 0
Offline Offline
View Profile
« Reply #24 on: February 23, 2008, 11:58:47 AM »
I know karate!
Morpheus: Show me.  Grin
Is that little circuit board between the arms a camera? The one with Sharp IR on top.. If yes, why is it closed?
Logged
AdminTopic starter
Administrator
Supreme Robot
Helpful? 62
Offline Offline
View Profile WWW
« Reply #25 on: February 23, 2008, 12:06:57 PM »
yeap, its a CMUcam
Its closed because its a blind ninja.
(actually, its to keep dust off the lens till I finish programming it)
Logged
paulstreats
Supreme Robot
Helpful? 12
Offline Offline
View Profile WWW
« Reply #26 on: February 23, 2008, 04:58:06 PM »
Ive just got a plain old camera module, im hopng to use it for better results than a cmu cam. The problem is that i need to program it with a lcd screen to focus it first blaa! why aint there no decent camera modules for robotics that use a low budget!
I mean how are we supposed to get people interested in robotics when its all too expensive (im working on it). I want to start a business but theres no point if it all costs so much, unless......
Logged
Asellith
Supreme Robot
Helpful? 7
Offline Offline
"I'm a leaf on the wind. Watch how I soar"
View Profile WWW
« Reply #27 on: February 26, 2008, 11:31:15 AM »
First amazing job admin. but I have a few questions. You mentioned CNC. Do you have your own or access to one? If you have one I was interested in getting one and wanted to know some recommendations if you have any. Also now that you have 2 arms wouldn't it be better to open the hands more so you could use both hands to pick something up instead of just one? That will allow you to pickup bigger objects like a pop can.
Logged
Jonathan Bowen
Electrical Engineer
www.lostministries.org
AdminTopic starter
Administrator
Supreme Robot
Helpful? 62
Offline Offline
View Profile WWW
« Reply #28 on: February 26, 2008, 11:52:24 AM »
When I first started making robots back in like 2002, prices were 2x to 3x higher, and only a 3rd the products were even available. And there was no SoR like website either Tongue I think this trend will continue.
I work for the Navy, so I have infinite funding Grin
I use the Haas Mini Mill, but its the only CNC I've ever used so couldn't tell you . . . I use an old version of EdgeCAM to plot the paths. Ideally, you want a CNC thats easy to learn, and low maintenance - the two biggest problems of a CNC (well, that and cost . . .). We also have a large air compression tank needed for the CNC operation . . . it has a tendency to corrode (despite draining it monthly) and needs to be replaced every 2-3 years.
I call it the ERP because its an Experimental Robot Platform. I'll only be adding features to it in the future - including new gripper ideas. Each gripper upgrade I add I'll do to only one arm, so that means the other arm will get an even better gripper in the next upgrade. I'm still thinking of adding a rotating wrist joint, too.
Actually, my distant long term goal is to slowly turn it into a biped. Slowly designing the technology for it, a bottom up design I guess . . .
I guess I'll make another update here. Last night I finished up 90% of the wiring, but my new batteries have yet to come in. Using my old batteries for now . . . Anyway I have it doing basic arm and head motions. Basic arm coordination is now working. Short term goals are to get it to dance, and to test out my CMUcam code (compiles, but no time to test it yet).
Logged
AdminTopic starter
Administrator
Supreme Robot
Helpful? 62
Offline Offline
View Profile WWW
« Reply #29 on: March 01, 2008, 07:28:09 PM »
In the last few days building this bot I've learned a lot of important lessons I'd like to share . . .
1) I have a table top drill press, with an attached X-Y table, and a small vice attached to that table. I often put a mill bit into it to convert it as a small mill. What I learned is using this to mill out the flange on the large gear when modifying servos is by far the best way to do it.
2) The HS-225BB can only be modified using lesson #1, or using a dremel (the hard way). A simple snip wont work unlike with other servos.
3) Replacing broken gears in servos is fairly easy, both with metal and plastic gears. Had to do both this week . . .
4) Battery pack manufacters aren't consistant on how they attach connectors. My new onlybatterypacks.com connector is reversed from my older battery, and I didn't notice . . . bringing me to lesson #5 . . .
5) Most servos won't break if you reverse voltage, however one of my HS-225MG servos went up in smoke . . . literally tons of smoke. A wasted $35 Sad My other HS-225MG, four of my HS-311's, a Futaba S3114, two HS-5245MG's, and two of my HS-225BB servos survived without a problem.
6) My Axon microcontroller 100% survived the reverse 6V 4500mA battery over a 5 second period. Proof that its noob proofed . . . and expert [without his thinking cap on] proofed . . . Always use a power light LED to clue you in quick!
In other news, I got my bot doing dancing and ninja attack moves with its arms/wheels today. Soooo glad I didn't fry anything else . . . The perfectly smooth CNC'd wheels don't work very well on smooth surfaces (expected problem), so I'll have to add some of my rubber tread material to it. I'll report on how that works out after testing.
Tried testing my CMUcam code, but it wasn't working, and I stupidly left my USB cable at work so I can't look at the output data for debugging . . . Good thing it was turned off when the voltage was reverse Smiley
6 weeks left to finish this bot . . .
Logged
Jump to:
Subject Started by Replies Views Last post
Ad: Make you Robot perfect-Robot components
Mechanics and Construction
zengyanyun56 1 2345 Last post July 18, 2007, 08:35:04 PM
by zengyanyun56
My First Robot - A Differential Drive Dummy Robot
Robot Videos
reefat 25 4593 Last post February 07, 2009, 01:05:28 AM
by horo333
My First Robot - A Differential Drive Dummy Robot (Version 2)
Robot Videos
reefat 8 3674 Last post November 14, 2008, 10:45:55 AM
by Kirk
Really annoying Slate article on robot products (robot bashing).
Misc
SciTech02 5 1303 Last post January 29, 2009, 03:21:27 PM
Powered by MySQL Powered by PHP Powered by SMF 1.1.10 | SMF © 2006-2009, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
Advertise on this Forum
