Society of Robots
     | Robot Forum | Robot Tutorials | Robot FAQ |
Welcome, Guest. Please login or register.
Did you miss your activation email?
November 20, 2009, 08:21:33 PM
Login with username, password and session length
Search:     Advanced search
SoR Robot Chat every friday night. Join us!
http://www.societyofrobots.com/robotforum/chat/
Robot Forum
72,665 Posts in 9,267 Topics by 5,289 Members
Latest Member: rac34125
* Home Help Help Login Register
Pages: 1 2 3 [4] 5 Print
Author Topic: arduino board help plz  (Read 34422 times)
robonoobTopic starter
Robot Overlord
Helpful? 0
Offline Offline
View Profile
« Reply #90 on: January 11, 2008, 05:50:07 AM »
okei admin it was a little too long(the butt) so i made it shorter and put the batteries on the bottom of the robot but i will use double sided tape instead of velcro(cuz i don't know a place to buy it from) and i will also mount the scanning servo with DST but what about the 2 driving wheels? how should i mount these?? :S
i mean like if these things: http://www.servocity.com/html/90_degree_universal.html come with the servo i am going to order( http://www.robotshop.ca/home/products/robot-parts/motors/servo-motors/hitec-servo-en/hitec-hs311-servo.html ) then i think i will use them.
the IR will be  mounted with a double sided tape(DST) as well.
PS: please give my last schematics a look and tell me if this would work as i described or not Smiley
thank you Smiley
Logged
Admin
Administrator
Supreme Robot
Helpful? 62
Offline Offline
View Profile WWW
« Reply #91 on: January 11, 2008, 06:19:28 AM »
You can get velcro at any hardware or craft store. I buy the $20 box of like ~20ft of velcro . . . lasts me about 5 years. But you can also buy small strips for like $2. I don't recommend double sided tape for batteries because its really hard/annoying to remove.
as for mounting wheels, dont double post!
http://www.societyofrobots.com/robotforum/index.php?topic=2729.msg19352#msg19352
And for your CAD, don't forget a method to mount your arduino onto the robot. You will of course also need room for your wiring, etc.
Logged
Ro-Bot-X
Contest Winner
Supreme Robot
Helpful? 10
Offline Offline
Current project: MiniEric robot.
View Profile
« Reply #92 on: January 11, 2008, 07:59:09 AM »
You may want to install the drive servos so that the wheel axle will be towards the back instead of towards the front. This way it will improve turning radius of the ball caster and still be well weight ballanced.
Logged
Check out my new blog!
 SeriousRobotics
Robot Overlord
Helpful? 0
Offline Offline
View Profile
« Reply #93 on: January 11, 2008, 03:47:34 PM »
umm i don't know if that's what u meant but this is what i did:
Logged
Ro-Bot-X
Contest Winner
Supreme Robot
Helpful? 10
Offline Offline
View Profile
« Reply #94 on: January 12, 2008, 09:56:50 AM »
Yes, this is much better. But you should also do the same for the Sharp Sensor since they have like 4 inch minimum measured distance...
Oh, and add bump sensors, just in case the robot can't see something lower than the range sensor.
Logged
 SeriousRobotics
Robot Overlord
Helpful? 0
Offline Offline
View Profile
« Reply #95 on: January 12, 2008, 10:10:39 AM »
the 4 inch doesn't matter because i will make the robot turn if the wall is like 30 cm's from the robot Smiley
but bump sensors? what are these?
Logged
airman00
Contest Winner
Supreme Robot
Helpful? 17
Offline Offline
narobo.com
View Profile WWW
« Reply #96 on: January 12, 2008, 05:19:02 PM »
bump sensors are contact switches
switch closed = obstacle
the obstacle hits the push button switch
Logged
Admin
Administrator
Supreme Robot
Helpful? 62
Offline Offline
View Profile WWW
« Reply #97 on: January 12, 2008, 08:25:22 PM »
but what if your robot turns into a wall?
Ro-Bot-X is right Tongue
Logged
Robot Overlord
Helpful? 0
Offline Offline
View Profile
« Reply #98 on: January 13, 2008, 01:26:46 AM »
oh... i never thought about that Cheesy anyways i will flip the scanner servo around too and then try the robot and if it starts hiting every wall then i will try making theese bump sensors  or something Smiley
edit: i put the scanner servo to the back i think this would work eaven better because my servo only rotates 90 degrees Smiley
PS: the fourth picture is about the range of view of the robot if i set the wall detection distance 30 cm.( about 12 inch)  Smiley
« Last Edit: January 13, 2008, 04:40:08 AM by robonoob » Logged
Admin
Administrator
Supreme Robot
Helpful? 62
Offline Offline
View Profile WWW
« Reply #99 on: January 13, 2008, 10:04:03 AM »
hey robonoob I really like your 4th pic with the IR scan range.
can I use it in my sharp IR tutorial?
Logged
Robot Overlord
Helpful? 0
Offline Offline
View Profile
« Reply #100 on: January 13, 2008, 10:19:33 AM »
but ofcourse Smiley it would be my honor Smiley
Logged
Trumpkin
Supreme Robot
Helpful? 5
Offline Offline
View Profile
« Reply #101 on: January 13, 2008, 03:56:40 PM »
you can get bump sensors from computer mice
Logged
Robots are awesome!
Robot Overlord
Helpful? 0
Offline Offline
View Profile
« Reply #102 on: January 14, 2008, 04:05:40 AM »
yea i have a lot of them but i think i wont need one Smiley but that will be clear after i have built my robot Smiley
BTW i will get a creditcard tomorrow and then i can order the parts tomorrow too Tongue but i dont know how much time it takes me to get the arduino cuz its out of stock wher i am going to buy it Sad
Logged
Robot Overlord
Helpful? 0
Offline Offline
View Profile
« Reply #103 on: January 14, 2008, 01:23:05 PM »
umm i recoved the credit card a day earlyer(fortunately) and i am now ordering the parts Smiley
but i have some questions...
http://www.robotshop.ca/home/products/robot-parts/sensors/infrared-sensors/sharp-gp2d12-ir-range-sensor-10-cm-80.html this thing comes without the cable? am i right? so i need to buy the cable aswell?
then: i've decided to buy this servo http://www.robotshop.ca/home/products/robot-parts/motors/servo-motors/hitec-servo-en/hitec-hs422-servo-motor.html and i was wondering if there are any mounting things with it? like this? http://servocity.com/html/90_degree_universal.html
 umm yea...this may be a stupid question but i really need an answer for this one too Cheesy can i mount my IR to the servo horn with this thing? http://www.robotshop.ca/home/products/robot-parts/mechanics/mounts-hubs/lynxmotion-multi-purpose-sensor-housing.html
http://www.robotshop.ca/home/products/robot-parts/mechanics/robot-wheel-track/tamiya-ball-caster.html are there mounting skrews added to the kit? you know like the skrews with what i can mount the caster to my robot chassis?
and then lastly i was thinking of ordering a sonar for my future projects cuz i dont want to order a second time this soon cuz the shiping here is just CRAZY and my question is: assuming that i will be using arduino then what sonar would you recommend from this page? http://www.robotshop.ca/home/products/robot-parts/sensors/ultrasonic-range-finders/index.html
i was thinking of this particular one here: http://www.robotshop.ca/home/products/robot-parts/sensors/ultrasonic-range-finders/devantech-ultrasonic-range-finder-srf05.html
PS: i want to get a cheap sonar Cheesy and if u reccomend me a sonar them please tell me why you would pick this one Smiley
PSS:i would need quite a fast answer cuz i cant wait to order the parts Tongue(too bad i have to wait a month to recive the parts because some of the things i'm gonna order oare out of stock Sad )
PSSS: can anybody please tell me why some sonars have 2 "speakers" (i dont know how they call theese things Cheesy) but some only have 1?
Logged
airman00
Contest Winner
Supreme Robot
Helpful? 17
Offline Offline
narobo.com
View Profile WWW
« Reply #104 on: January 14, 2008, 02:54:14 PM »
the IR rangefinder does not come with a cable
the 90 degree mount is good also, but remember to get the screws that come with it
yes you can mount the sensor on that mount
ok the casters come with mounting machine screws
I would get the Maxsonar EZ1 , its the easiest to use
the reason why they have 2 speakers ( aka transducers) is that one is transmitting and one recieves. When there is only one transducer than that one transducer switches off being transmitter and reciever
what material are you using for the chassis?
Logged
Robot Overlord
Helpful? 0
Offline Offline
View Profile
« Reply #105 on: January 15, 2008, 05:32:56 AM »
umm okei so what does that mean? "but remember to get the screws that come with it"
why do i have to get the screws that allready come with it anyway?
what are mounting machine screws? are these the screwa i need to mount the caster to my chassis?
how should i mount the Maxsonar EZ1?? any products from www.robotshop.ca please Smiley or if there arent any then please suggest me a sonar that i could mount on that: http://www.robotshop.ca/home/products/robot-parts/mechanics/mounts-hubs/lynxmotion-multi-purpose-sensor-housing.html
edit: i think i will buy this sonar: http://www.robotshop.ca/home/products/robot-parts/sensors/ultrasonic-range-finders/devantech-ultrasonic-range-finder-srf05.html because it can measure from 1 cm to 4m.
what do u think about that sonar?
also: hot to wire this sonar to my arduino i cant see any wires coming out of the device? :S
and i still didn't get the answer to my question: what comes with the servo?
edit2: I CANT FIND SPACERS ANYWHERE!!! could somebody tell me how are they really called? i dont belive they are called spacers cuz i just cant find any of the tings i need with the spacer as a keyword :S
it would be good if there are any sale on www.robotshop.ca Smiley
« Last Edit: January 15, 2008, 06:26:37 AM by robonoob » Logged
Admin
Administrator
Supreme Robot
Helpful? 62
Offline Offline
View Profile WWW
« Reply #106 on: January 15, 2008, 06:24:54 AM »
you will have to add your own wires. something like this:
http://www.societyofrobots.com/electronics_wire_connector.shtml
just like connecting stuff to the $50 Robot board
Logged
airman00
Contest Winner
Supreme Robot
Helpful? 17
Offline Offline
narobo.com
View Profile WWW
« Reply #107 on: January 15, 2008, 06:32:41 AM »
Ok the servos do not come with any mounting things for the servo itself, you'll need to buy the servo mount separately. in the servo box you get the servo and a bag of these
by screws that come with it , i meant the screws that are compatible with the 90 degree servo mount . these screws http://servocity.com/html/_4_truss_head_phillip_screws.html
With the casters you get these . The casters come in kit form, they are extremely easy to build and what I like about it is that you can build them up in different ways to give them different heights.
The SRF05 is fine also , just you have to solder on wires to the pins. Look at the technical specifications of it to see what the PCB holes are for.
Its basically a two wire interface to your MCU. I like the Parallax PING ultrasonic sensor since it is a one wire interface , so if you can get a PING, get it!
Logged
Robot Overlord
Helpful? 0
Offline Offline
View Profile
« Reply #108 on: January 15, 2008, 07:03:51 AM »
okei so i found this picture: http://www.superdroidrobots.com/product_info/SRF05/srf05p2.jpg can i programme and use this sonar with the arduino? and what's with the echo output and trigger input? where do i need to connect these?
Logged
Admin
Administrator
Supreme Robot
Helpful? 62
Offline Offline
View Profile WWW
« Reply #109 on: January 15, 2008, 07:05:58 AM »
its all explained here Wink
http://www.societyofrobots.com/sensors_sonar.shtml
Logged
airman00
Contest Winner
Supreme Robot
Helpful? 17
Offline Offline
narobo.com
View Profile WWW
« Reply #110 on: January 15, 2008, 07:09:47 AM »
its all in admins tutorial.
trigger input is basically your trigger switch shooting out a sonar signal for i think 10uS ...... then you wait for the echo output which you then convert to inches or cm
Logged
Robot Overlord
Helpful? 0
Offline Offline
View Profile
« Reply #111 on: January 15, 2008, 08:31:45 AM »
anybody please tell me where to buy these "spacers". i need to mount my arduino with them but i cant find any :S
Logged
airman00
Contest Winner
Supreme Robot
Helpful? 17
Offline Offline
narobo.com
View Profile WWW
« Reply #112 on: January 15, 2008, 08:34:39 AM »
look at hardware stores , Home Depot may have one
Logged
Admin
Administrator
Supreme Robot
Helpful? 62
Offline Offline
View Profile WWW
« Reply #113 on: January 15, 2008, 08:35:17 AM »
you didn't look Wink
type spacer into mcmaster, its the first link
a few are on the first page of a google search
digikey and mouser have them too
Logged
Robot Overlord
Helpful? 0
Offline Offline
View Profile
« Reply #114 on: January 15, 2008, 09:06:39 AM »
yea but arent there any for sale in www.robotshop.ca?? i dont want to order from any other places because i will order all the other parts from there and the shiping to here (estonia) is very very expensive :S
Logged
airman00
Contest Winner
Supreme Robot
Helpful? 17
Offline Offline
narobo.com
View Profile WWW
« Reply #115 on: January 15, 2008, 09:10:27 AM »
why not just put something soft under the arduino and then screw a screw through the arduino's hole and through the material into your board
you have any hardware stores in estonia?
Logged
Robot Overlord
Helpful? 0
Offline Offline
View Profile
« Reply #116 on: January 15, 2008, 09:17:22 AM »
lol Cheesy yea ofcourse we have but i dont live near to any of em... :S but i will look for something soft to mount the arduino Smiley thank you for that idea Smiley oh hey it just reminded me that i have some of theese rubber "Standoffs" from an old CD-ROM Tongue i think i could use them Tongue
and i still dont know how i will mount the batteries onto the bottom of my chassis...
« Last Edit: January 15, 2008, 09:20:54 AM by robonoob » Logged
Trumpkin
Supreme Robot
Helpful? 5
Offline Offline
View Profile
« Reply #117 on: January 15, 2008, 10:56:08 AM »
just get some velcro, I don't now what kind of stores that you have in estonia but if there is a wally-world (Wal-Mart) you could find some there.
Logged
Robots are awesome!
Robot Overlord
Helpful? 0
Offline Offline
View Profile
« Reply #118 on: January 15, 2008, 12:12:47 PM »
guess again lol Cheesy i dont think that we have wal-mart Cheesy but i'll see if i can find some velcro somewhere Smiley
okei next maybe this is a software question more than an electican one but i dont want to make another topic about it Smiley anyways here it is: what is the analog output range of the Sharp GP2D12 IR Range Sensor?
i dot know if i expressioned myself clearly but what i mean is that from where to where does the sensor give me the reading to my arduino board?? like the POT gives from 0 to about 1000 and so on. i would like to be as accurate as possible Smiley
thank you Smiley
oh btw i finally ordered all the parts(hopefully its all i need) but i may have to wait for 3 WHOLE MONTHS to recive these parts :S and maybe eaven more cuz some of the parts were out of stock...
PS:please tell me if i have to make another topic or can i ask the arduino programming questions here too?
Logged
Admin
Administrator
Supreme Robot
Helpful? 62
Offline Offline
View Profile WWW
« Reply #119 on: January 16, 2008, 11:21:47 AM »
spacers are easy to make . . .
you can also use those square little rubber pads that come with the servos as a spacer.
well, keep related posts together, otherwise Ill leave it up to you to decide.
Logged
Jump to:
Subject Started by Replies Views Last post
maby a arduino usb board for monk?
Electronics
maverick monk 13 2744 Last post July 04, 2007, 06:39:51 AM
by megaman935
neat arduino compatible board!!!
Electronics
sonictj 1 1158 Last post August 10, 2008, 08:15:56 AM
Question about Arduino board
Electronics
clone 5 1085 Last post January 14, 2009, 01:06:17 PM
by clone
Arduino the power hog!- help with running the Arduino at a lower voltage (3.3v?)
Electronics
Hawaii00000 4 1458 Last post January 16, 2009, 08:07:32 PM
by Kirk
Powered by MySQL Powered by PHP Powered by SMF 1.1.10 | SMF © 2006-2009, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
Advertise on this Forum
