Author Topic: new Axon and $50 Robot bootloader  (Read 24663 times)
Offline AdminTopic starter
« on: November 25, 2008, 10:48:56 PM »
If you have an external hardware programmer, try out the latest bootloader v2.1 (attached). I just compiled and tested it, so maybe it will solve some problems the older version had.
Select the appropriate file and upload it using AVR Studio.
None have been extensively tested, so you'll be a beta tester ;D
Please report your findings here!
Offline adasta
Re: new Axon and $50 Robot bootloader
« Reply #1 on: February 04, 2009, 09:38:43 AM »
This boot loader fixes the WDT timer on the Axon.
With the previous boot loader it would not execute.  However, now it does so correctly.
« Reply #2 on: August 12, 2010, 03:13:18 PM »
Its been extensively tested, no problems ever came up.
I also attached a file for the ATmega1280 and ATmega2560, if anyone needs it.
Offline voyager2
  • Helpful? 6
    • Voyager Robotics
« Reply #3 on: August 12, 2010, 06:54:03 PM »
Do these work with Windows XP sp3?
If so i might consider getting one...
Do we have to download the "old" fboot17.exe file, or whatever its called. ::)
And it was good.
« Reply #4 on: August 12, 2010, 07:03:56 PM »
It works with sp3 . . . very very slowly. 'Downgrade' to sp2 for USB to work properly.
You should use v21 with these.
