Society of Robots
     | Robot Forum | Robot Tutorials | Robot FAQ |
Welcome, Guest. Please login or register.
Did you miss your activation email?
November 20, 2009, 05:49:55 PM
Login with username, password and session length
Search:     Advanced search
SoR Robot Chat every friday night. Join us!
http://www.societyofrobots.com/robotforum/chat/
Robot Forum
72,657 Posts in 9,264 Topics by 5,289 Members
Latest Member: rac34125
* Home Help Help Login Register
Pages: [1] Print
Author Topic: 5th SoR robot contest now open  (Read 902 times)
AdminTopic starter
Administrator
Supreme Robot
Helpful? 62
Offline Offline
View Profile WWW
« on: September 30, 2009, 06:25:11 PM »
I am now declaring the 5th contest:
http://www.societyofrobots.com/free_robot_contest.shtml
The rules have changed slightly from previous years.
The dates are chosen based on winter vacation - you have the holidays to finish! If you have already written a robot tutorial and didn't win in a previous contest, you can re-enter it in if you want (but it must be improved).
Everyone that is participating make a single post here declaring their entry. (do not email me!)
Include two things:
1) Short paragraph that describes what your robot will do when its finished.
2) Picture(s) that represent your robot as a whole (yes, a CAD image is also ok).
IF YOU ARE NOT ENTERING THE CONTEST, DO NOT POST HERE
ASK ALL QUESTIONS IN ANOTHER POST, PLEASE!
Make it good: this is also a sort of 'pre-advertising' to win you more votes later.
As soon as you do this, I will set up a web account for you (if you do not yet already have one).
Also, *do not* ask me anything about the Axon II, even though its the 1st place prize. No exceptions.
Logged
MangoBot
Robot Overlord
Helpful? 1
Offline Offline
View Profile WWW
« Reply #1 on: October 11, 2009, 04:44:08 PM »
Name:ARP or Autamatic Pet Feeder
Purpose:Autamatically fill a food bowl with food so that a pet will always be fed.
Parts: 2' of 2" pipe
        3 90 degree angle corners
        2 metal can
        Misc. Small screws
        Lego Mindstorms NXT 2.0. Some info on it is on the link below.
http://mindstorms.lego.com/eng/Israel_dest/default.aspx
Other: 2 motors will allow food to flow into the bowl, and a light sensor will close the pipes when the food covers the sensor because of the lack of light
« Last Edit: October 30, 2009, 06:42:02 AM by MangoBot » Logged
airman00
Contest Winner
Supreme Robot
Helpful? 17
Offline Offline
narobo.com
View Profile WWW
« Reply #2 on: October 11, 2009, 05:10:27 PM »
I'll be doing an extensive tutorial on my omniwheel robot that plays soccer.
Soccer Robot Scoring GoalLQ | HQ
Logged
dellagd
Supreme Robot
Helpful? 2
Offline Offline
Come to the dark side... We have cookies!
View Profile WWW
« Reply #3 on: October 12, 2009, 03:50:33 PM »
hey guys, entering my SUPER easy to build BS2 robot for BS2 beginers with no place to go and are looking for a nice project.
My (w/ friend's help) wall-avoiding robotLQ | HQ
The shake test for my robotLQ | HQ
can be built for around $30
Great $50 bot alterative for under $50 if you have the board and are stuck with it.
PVC frame also makes it highly expandible off of.
(instead of pic I pit video)
This robot can scan its surronding and not run into walls, pretty self explanitory.
Also with the PBASIC language you could easily adapt this to a photovore robot.
This is a great beginner robot with its very easy to grasp language and nice interfacce.
The Della-WAHR is also much more expandible than having to BUY attachments for the Parallax Boe-Bot
Videos with some steps also help alot when following the tutorial
Before the break comes I also plan on making a motored (not servo) version and also more attachments
Vote for me!
http://www.societyofrobots.com/member_tutorials/node/323
« Last Edit: October 13, 2009, 04:20:59 PM by dellagd » Logged
Like Rockets?
I'll be selling them soon!
check out My Website
Wana say something?
44 characters for sale
thebeardedone
Beginner
Helpful? 0
Offline Offline
View Profile
« Reply #4 on: October 13, 2009, 03:24:07 AM »
My robot will be an entry for the RobotChallenge 2010 in Vienna.
Robot name: Ookami
Class: Mini Sumo Bot
Description: Ookami was inspired by the robot designs seen on the UK series of robot, especially Panic Attack built by Kim Davies. Although it is not a combat bot, I wanted to come up with a design that has a medium profile and a solid frame. It will utilise the sharp IR range finder mounted on a servo, green dot compound tires and will have a frame built using HDPE or ABS plastic. It will then be sprayed in black. I will also make use of a Roboduino and it will be programmed in C.
I have included some CAD images for your viewing pleasure (not to scale and not particularly accurate or pretty):
Isometric Left
Isometric Right
Front
This is my first robot build, but I have been doing electronics for some time.
Thank you.
Logged
Asellith
Supreme Robot
Helpful? 7
Offline Offline
"I'm a leaf on the wind. Watch how I soar"
View Profile WWW
« Reply #5 on: October 14, 2009, 06:58:08 PM »
OK announcing my entry into the contest....
Concept is to be a 3 wheeled omnidirectional robot. The first iteration of the unit will be a simple object avoidance robots.
The main control unit will be the Axon connected to at least one, possibly two, if time allows, modules base on the OSCAR specifications. At this point the Axon can do everything that the modules will do but the idea is to make building blocks that allow users to easily create complex robots quickly and efficiently without having to learn the intricate details of how a sensor or function they want to perform is done.
The two modules to be included are:
1. Distance sensor module to include the EZ1 sonar sensors and possible sharp IR sensors. Object avoidance and wall following functions will be included
2. Servo control with options for simple navigation using omni wheels. I.E. Main controller says go at angle 45 or rotate 90 degrees on center and the module handles what the wheels do.
I plan to write 3 complete tutorials for this project.
1. Construction of the robot chassis
2. Implementation of Multimaster I2C communication using AVR MCUs
3. Code and Manual for use with any modules created
I want this little guy to be the first complete OSCAR robot and a test platform for future modules.
Logged
Jonathan Bowen
Electrical Engineer
www.lostministries.org
offy
Supreme Robot
Helpful? 1
Offline Offline
View Profile WWW
« Reply #6 on: October 26, 2009, 06:04:49 PM »
I am going to enter my "SnR Robot" for Search n' Rescue.
Task: Find human in woods, signal for help, and drop off goods for human
Go back to base, and lead people to the human that needs help
Started: October 24th 2009
Est End: December 5th 2009
Chassis Progress:
« Last Edit: October 29, 2009, 09:23:45 PM by offy » Logged
TrickyNekro
Contest Winner
Supreme Robot
Helpful? 5
Offline Offline
We are our choices
View Profile WWW
« Reply #7 on: November 06, 2009, 06:05:13 AM »
Since I only got to finish the robot and document it, I think that I'll make it
and so I'm entering...
I'll be entering with my autoparking vehicle
This was first intend to be a GPS UGV but time was short and I need it to be ready for a
robotics exhibition at my country so I only made it to park based on the measured free space
through the encoders and the existence of free space or not... Not being able to park in tight situations...
I hope I'll be able to fit the sensors and to the programming until the end of the period available...
Here's a picture from the exhibition... (nice days!!!)
Logged
Rule your destiny.
Be good. Be bad. Be Lee.
LiPo.... Nice batteries, but hard to use?
No prob...
http://www.societyofrobots.com/member_tutorials/node/302
If you liked it.... Vote it!!!
awally88
Robot Overlord
Helpful? 0
Offline Offline
View Profile
« Reply #8 on: November 09, 2009, 07:16:18 PM »
I'm looking at making a logo turtle based robot which can be controlled wirelessly.
The logo langugage for those who don't know is a an old simple language which was commonly used to program a turtle-like robot which could be controlled using statements such as forward 10, leftturn 90, back 20 etc.
The original design for this looked awful so I'm going to design a wireless version of this which will hopefully have a nice gui control as well as looking pretty sweet itself. The computer side programming will also have some functions which will aid in drawing shapes and hopefully words if time permits.
I will provide more details/CAD as soon as I finish my end of year exams.
Logged
vidam
Supreme Robot
Helpful? 0
Offline Offline
Robotronics.org
View Profile WWW
« Reply #9 on: November 13, 2009, 06:13:09 PM »
I'm making a tutorial to compete in the Penn State Mini Grand Challenge 2010. It will give the technical approach used to compete from hardware and software. Also you will get to see how the approach fails/wins in April 2010.
Logged
spykid99
Jr. Member
Helpful? 0
Offline Offline
View Profile
« Reply #10 on: November 14, 2009, 05:42:06 PM »
Here's my 2 pence!
Concept is scaled down transport ship that can:
  • Dock
  • Maneuver Obstacles
  • Navigate to a Target
Controlled autonomously or remotely via computer GUI
More details and a CAD to follow!
Spykid99
Logged
"Do not worry about your difficulties in Mathematics. I can assure you mine are still greater." ~Albert Einstein
Hadamard
Beginner
Helpful? 0
Offline Offline
View Profile
« Reply #11 on: November 17, 2009, 08:23:44 PM »
I plan to finish building a carpet rover robot that uses ultrasonic range finders and a CMUcam. Its purpose is to avoid obstacles and follow a red object (such as a ball).
Major Parts:
1 Parallax Javelin Processor
2 Parallax Ping Ultrasonic Range Finders
2 HiTEC HS-422 standard servos
2 HiTEC HSR-1422CR Continuous Rotation Servos
1 CMUcam (1st Generation a.k.a. Boebot CMUcam)
Right now I have the entire robot built and working except for the CMUcam. I have just recently started tinkering with it and need to figure out how to mount it on my robot.
Later I will post a video of it in action.
Logged
Pages: [1] Print
Jump to:
Subject Started by Replies Views Last post
the 2nd $200 Robot Contest now open!
Misc
Admin 17 8659 Last post March 17, 2008, 06:00:55 AM
the 3rd $200 Robot Contest now open!
Misc
Admin 22 10576 Last post September 19, 2008, 11:02:29 AM
the 4th $200 Robot Contest now open!
Misc
Admin 12 6074 Last post March 21, 2009, 02:41:43 AM
Open Source Robot Arm
Mechanics and Construction
airman00 1 1032 Last post March 27, 2009, 06:23:23 AM
by Ryltar
Powered by MySQL Powered by PHP Powered by SMF 1.1.10 | SMF © 2006-2009, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
Advertise on this Forum
